I am new to the Supras and im looking into buying a 1JZ. My question is about making a 1.5JZ without swapping the entire lower block. Since 1JZ bore is same, but 2JZ has longer stroke and the block/head pretty much bolt up...instead of buying lower block, why not just swap crank, rods and maybe cams and tune it? Are the cylinders also longer in 2JZ? would you have to machine/fabricate the 2JZ crank to fit? or is there not enough room to put the rods/crank in crank case?
