Non_Turbo vs Turbo Engine Head
8,894
If you look at the Jeff Lange spec sheet in the refrence section, the 91 repair manual shows 171 psi cylinder pressure, from the original 156, and 140ish or whatever the GTE is. That is where the spool and short term power gain is. That elevated cylinder pressure. But with less lift, you will lose out in the end. And with an 86.5-88 GE used cam, there probably is not any gain.
89mkthree
supies ignore irish luck!
Apr 12, 2005
138
near chi town
its the intake. it is proven, do a little searching on it and youll find a link to supraforums hat has dyno charts for proof. i heard its different 88+ not 89+, but that one im not sure about.
8,894
I don't know what year the intake cam switched either. The repair manual should have that information in the commpression test section.
