yes i willfstoy said:Wanna sell the non abs lines and valve, if you decide to go ABS?
i'm pretty sure you can make an over ride switch just in case those times when you want to screw around or dont want it :naughty:Jayhall said:My abs sucks dick, every time it rains ive got to deal with it coming on when its not wanted
i like abs, and dont like abs. it depends on what im doing etc......suprabad said:I don't have that problem. Maybe there's something out of whack with your abs.
i sure hope mine has the built in harness if not i'll find a pin out and try making my own harness :naughty:supradavenz said:i too was going to do this to my 7mge-7mgte conversion but i decided against abs. it looked semi easy in my eyes. my car came with the ABS optional loom so all the plugs were there just needed hubs, lines, ecu, abs unit and the ??sensor for the gearbox??
Some of our jdm chassis here didnt get abs optional harnesses how about you guys in the states? do they all have that harness?
Poodles said:IF you have all the parts, do it...
It's going to be a lot of work, so I'll worn you now... You'll have to mess with a LOT of items (gotta run the computer's wires, swap out spindles, ect ect ect)
