Noise filter wire?
rawmk3
170
IL
I also took a look at my noise filter, and its grounded to a point on the ignitor bracket, and is a small black resistor looking part. It has that white connector with two wires, one black with orange stripes, and one white with black stripes. I can take a picture of it for you if your would like. I cant say for sure if that would give you an ignition issue, because I have my car half tore apart, and cant fire it up at the moment.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
I ordered a new one (ground wire with other side connector) from Toyota today, I'm hoping it is my problem but, now that I think about it, I don't think I would have hooked it up when it was running because I don't remember taking that piece (as well as anything else) off the body, but I hope I'm wrong.
I know the wire goes through both sources of my power problems. If someone with a running car could disconnect theirs just to see if it runs without it, I would be ever so greatful :)
92nsx
2,957
Clearwater, MN
Is this what you are looking for? It is located next to the fuse box.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Not getting a breaking ground to the coils, ignitor is good and getting power, cps is good and getting power, I saw that the noise filter wire went through wiring where my problem was and was hoping it might be my problem but now it looks like its the ecu...unfortuatley the aem ems is not a cheap replacement unless the settings are somehow messed up...
87nasupra
Scotty's Garage
Mar 2, 2006
993
Jacksonville, FLORIDA !
Have you tried starting at scratch and going over it again? just retrace steps ya know. I'm sure its something simple.
