NO SPARK
Status
Not open for further replies.
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
Which ones do i need to JUMP. Also the accordian hose from the Maf to the Turbo is cracked at the turbo so it needs to be replaced may have a leak
isnms
United States of America
Oklahoma
i80.photobucket.com
mcpcola said:
yep but i have having trouble still now the timing is bouncing from 10 to 15 at idle like it has a miss
Let us know how you fix this.
I've replaced plugs, wires, coil packs, cps, igniter, fixed connectors and still have a bouncing timing mark.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Your timing is supposed to advance and retart when running at different temps and rpms.
YOU MUST JUMP THE DIAGNOSTIC PORTS (JUST LIKE YOU'RE READING A CEL) BEFORE YOU CAN CHECK THE TIMING.
mcpcola
Jul 4, 2005
428
Greater Gulf Coast
well I jumped the ports and its running at 10 on the money. I put in new wires and plugs NGK plat and I rewired the O2 due to the wires broke off no more codes but it still seems low on power and vibrates like it has a miss somewhere
MDCmotorsports
Indy 500
Check cam timing.
isnms
Oklahoma
i80.photobucket.com
I have changed cps, but I have a third one coming now :x:
edit: mcpcola - I'm not going to hijack your thread. Just wanted to see what you did to fix the bouncing timing mark. My issue appears to be something different than yours. GL.
mcpcola
Jul 4, 2005
428
Greater Gulf Coast
MDCmotorsports said:
Not really. If the cam's notch marks are straight up, and the crank is right at 0 deg, you're good to go.
Thanks man I will pyshically retime it this afternoon Thanks MDC for your info and continued help on this.
mcpcola
Jul 4, 2005
428
Greater Gulf Coast
well i checked the timing and It is as close and you can get it by eyeing it. We got some parts coming and i will post when they get here Laterz
Status
