Cajunkenny, What am I trying to do by wiggling wires? Thanks for the tip... I notice a little oil in the CPS near the bottom pick-up. I plan to buy another O ring for it. Will that oil cause ignition problems? VanCajunKenny;1603786 said:Van: Indexing your plugs will have minimal gains if any. And in the case of using more washers....likely that is doing more harm than good.
Try wiggling your CPS wires. You don't want to jerk on them like you're trying to start a weedeater; but, tug on them a bit.Also, try wiggling any other wires you can reach.
