No spark on my 89 turbo
mk3sons
206
New Hampsire
IBoughtASupra;1519589 said:
T-MA71, that is what I told him. If the "Check Engine Light" does not come on, it means that the ECU is either bad or is not getting power. Obviously, we all would check for power before we try a different ECU. Like Crazy said, check +B and B to see if you are getting 12V when the "Ignition" is on. If you are getting power, then the ECU is bad. If you are not, try checking the "EFI" fuse under the hood.
or maybe the dumb ass Po took the bulb out? yes i know from experiance there are some that dumb.
