Make sure the car is full of oil. Dont run it for very long until you get this fixed or you know for a fact that the motor has good pressure. Try a different sender. If that doesnt work then I would just get an Autometer oil pressure gauge.
Perhaps a dumb suggestion...did you check the connection at the sender?
The connector has a rubber cap (or should) that fits around the dome top of the sensor. The connector is inside the cap and is a bit of a pain to attach properly.
