No oil pressure
canadian
Newbie
May 16, 2006
366
Victoria BC
Drove the car around and noticed I had no oil pressure. What causes this? The sender I am using is from my old engine so I hope it stilll works.
How can I fix it?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Make sure the car is full of oil. Dont run it for very long until you get this fixed or you know for a fact that the motor has good pressure. Try a different sender. If that doesnt work then I would just get an Autometer oil pressure gauge.
mkIIIman089
Ohio
If he drove it around he would have already known if there really was zero oil pressure or not.
I recommend you skip Chinameter and go for something better if you choose to go that route.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Perhaps a dumb suggestion...did you check the connection at the sender?
The connector has a rubber cap (or should) that fits around the dome top of the sensor. The connector is inside the cap and is a bit of a pain to attach properly.
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
My gauge quit working right after my first engine swap. I raised hell with the shop, made them put in a new sender...
Then when I put a new gauge in it ($42 from Toyota) it started working again. LOL. Oops. :icon_redf
