Ok all, After getting everything installed and in Specs, I start the engine up and Notice that my Oil Pressure gauge isnt moving at all.
I do the following
Replace oil Sending unit
Replace Wire tip for sending unit
Replaced Instrument cluster with one in good working condition Gauge
Since Im running a Oil relocation Kit, I removed the oil filter to make sure I didnt have the Lines Crossed, Started the engine and Oil Immeditely shot oil of the oil Hole going into the filter, I put the oil filter back on.
So after all this, I started the engine up and Im still not getting any old Pressure. Since its a Freshly rebuilt engine with no more that 1 Minute Idle time, Should the Gauge Automatically start to read once the engine is started or does it take a minute.
Thanks for all those whom can help me out here, Is there a Fuse or something that I need to check for?
Robert
I do the following
Robert
