No intercooler? would it be safe?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
supr88 said:
i was thinking of using water/methanol intercooling on my supra with no air to air intercooler because of the quick spool.... seems like a good idea to me with water intercooling.
In this specific case I would view the meth inj. as a bandaid...
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
This would be an interesting set-up on a 7mge w/ stock electronics and injectors if you kept the boost low. Also an ignition box that retarded the timing at higher (not too high) boost levels would probably be helpful.
Has anyone done this?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
how so? it cools the intake temperature, and has the same goal as an intercooler. using meth as a bandaid would be using it to provide more fuel to a motor IMO.
Kckazdude
1,239
Memphis, TN
My 87 Conquest was a non-TSI version. This meant it had no wide body kit and no IC. The drawback to no IC was the lower then average boost level. 4-6 PSI boost was max recommended for no IC.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
But it would be a good, cheap alternative to a "no power" na set-up.
I wish I knew someone who had done this to hear how it worked out. (I have a 7mge on an engine stand gathering dust as well as a stock turbo, intake and exhaust).
hellraiser456
130
canada
if you keep it at stock boost and don't allow boost for extended periods of time (ie always floored or very high speeds) you will be fine. though you will notice a difference using one.
what they do is they cool down the air charge (because pressure creates heat) so you can (A) cram more air molecules (more oxygen) and thus more power and (B) the more core function as already stated is to cool intake temps so your combustion temps will become lower and thus you can push your engine a bit harder.
Water to air systems are great for lower power setup ups and drag racing (probably drifting as well). Since an air to air intercooler needs air to come across it, it works better the faster (more air) passes though it. a water to air intercooler isn't effected by that nearly as much (though speed still helps) if you wanted say no more that 450 hp then it would be a great. it would allow great cooling off the line (witch air to air have trouble with right away) and still have good performance at high speeds, IT also would be harder to heat soak if the setup was good.....though from what i see the air air ones will preform better at higher speeds...which in most cases is where you are really going to need it anyway. i have seen some setups and plans for both but that seems expensive and for the gain you would theoretically feel...pointless.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
It'd suck to have to refill every now and then. What'd happen if you ran out during a race or just spirited driving? You don't run out of intercooler ;).
