No injector pulse? help please!
beerxd
51
bkny
i checked the codes again today and the only one that came up was 51.. the water temp wire came off the plug i fixed that
im thinkin about buyin a new tps.. i took out the old one and the spring inside was stuck slightly open when i wud open it wouldnt close all the way..B
beerxd
51
bkny
it broke it was brittle.. i need to get an old one and set it.....
thanks aj for the help i appreciate it
the problem im gettin now is that the car wants to turn on it turns on revs high sometimes then stalls... other times it turns on and slowly stalls out.. im out of ideas and i need my car to get to work and get to school
ifyouaint1sturlast
Banned Scammer - I'm whitemike.
Jun 14, 2011
480
Fort Myers/Cape Coral - Florida
I have a brand new in box from Toyota TPS for a 7m. Let me know if you need it.
I don't know why you're out of ideas. Get your codes ALL fixed. Then proceed. You don't fix anything when other things are broken just because you think they're unrelated.
beerxd
51
bkny
I mean until i get the tps nd the only code i got was 51... Which is something with the tps
Thats the only broken part nd im missing the metal pipe that connects the bypass valve down to the hose by the vsv.. Not sure if that would cause my car to act up
My friend has one for me but how much are u asking?
