No Fuel Pressure
supranatural
17
Oregon
Alright, I'm new to upgrading fuel systems and I didn't know that the fuel pressure needs to be relief? and EFI fuse need to be pulled from the fuse box? I just went ahead and installed new 550cc RC injectors, Aeromotive AFR, and Walbro 255 fuel pump. Now, when I go and start the car after installing all those goodies in, the car won't start..I'm getting NO FUEL PRESSURE..I know the fuel pump is working because I've already tested it hooking it up with the car battery charger with 12volts and placing the fuel pump into a bucket of fuel. My question is: How can I get my fuel pressure back??? will replacing the EFI fuse with a new one solve the problem??
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Only if it's blown...
So what all did you actually do while changing everything out? Sounds like you have something disconnected that you don't yet realize is...
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Yep^^^^^ Open your hatch, lift the panel for the spare tire, and look under the cap that goes to your fuel tank to make sure you plugged everything in.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
supranatural;1075532 said:
............and EFI fuse need to be pulled from the fuse box...............will replacing the EFI fuse with a new one solve the problem??
I'm a bit confused. Are you trying to start the car with the EFI fuse out? If so, you're car will never start until you put that fuse back in.
shaeff
Kurt is FTMFW x2!!!!
9
Around
With everything back in place, use a jumper wire to connect +B and FP in the diagnostic block. See if you get pressure that way.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
You have to have the key in the ignition for this to work, I don't recall if it was the acc position or the on position but that diagnostic box doesnt get 12v with the key out (in my car at least)
montego6500
136
Burlington, Wisconsin, United States
i got the same issue no fp unless i jump wires in the diagnostic box. what gives isnt the fuel pump suppose to kick out when u turn the key on. im just getting done puttin in my fresh motor and what not. it worked with the walbro before rebuild
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
I don't recall off the top of my head, but I believe it's the ign signal that starts the fuel pump
I know for sure the pump will not run with the key in the on position, unless the car is running or being started. (or the diag box is jumpered)
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
Have you tried adjusting the AFPR? I don't believe they come setup in the box. Did you get a gauge with it? Try turning on the key and jumper the fuel pump test terminals and adjust it.
_
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
...maybe you should read my post again
The pump does not run with just the key in the on position, it must be starting or running
thejrman
99
omaha nebraska
thats weird because most cars i have messed with the fuel pump kicks on when the key is in the on position so it can prime the fuel system
jetjock
creepy-ass cracka
9,439
I'll tell ya what's weird. Nah, never mind....
The fuel pump doesn't run until the key is in the start position. Thereafter it runs only as long as the engine is receiving CPS signals on a turbo motor or air is flowing through the AFM on an NA. While many cars do prime for a bit with the key on every one made since around the early 80s has to use employ some method of shutting the pump off if the engine stops. It's the law, designed to prevent you from becoming crispy after a collision...
