No AFM Signal. ECU pin voltage help.
chevyguyjoe
55
Ft. Madison, IA
Cliffs notes version:
Have a MAF code. Changed AFM several times. No change. Changed AFM plug and 6 inches of wire, no change. Checking voltages at ECU all of them checked within spec, except KS to Body ground. Spec is 2-4 volts. Mine checked 5.06v. Is this good or bad? If bad does that mean i have a bad ECU?
