what about timing controll? say for up to a 100 shot. would reducing Base timing cure this issue?
yes !!nosechunks said:what about timing controll? say for up to a 100 shot. would reducing Base timing cure this issue?
toyman1987 said:Here is pics from my stealth install,
Nitrous:
No Nitrous::naughty:
looks like you might even be able to move that one over a bit and get two in there, maybe.Kyle87T said:Thats EXACTLY!!!! what I want to do and Upgradedsupra said it couldn't be done
I CALL FOR MORE PICS!!!
nosechunks said:so about that timing issue, lowering base timing to about 5 degrees would be good for anything up to a 100 shot safely?
suprarich said:If you ot a slightly used stage one nozzle kit for that price, you did really well. New they are over 500.00
Duane is correct, the bottle must be mounted on an angle with the valve up. This is why a 10lb bottle will not hide in the spare tire well. For up to a 75 shot on premium gas, you should be fine doing nothing else but hooking the kit up. All the other items you want as add ons will help the kit be better, but are not absolutly needed.
upgradedsupra said:Well I haven't had any carpet (OEM stuff) since 01 so couldn't remember...BUT
The bottle mounting seems to be laying flat which is not what you want. To get proper flow you need to have the bottle mounted on an angle..Is this on an angle?
Duane
toyman1987 said:The bottle is mounted at an angle, using the brackets that came with the kit. If you look at the pic closely there are little plastic spacers under the steel mounting plate for the wood cover. I also raised the little compartments on the sides the same amount so it's all level and still has support.
Kyle87T said:I wasn't exactly aware of that. I figured they were pretty mandatory items, I was going to start with a 50 shot and work my way up. If I can spray a 75 shot with no problems then I will wait out on the other parts until I get serious, but all it comes with to control the nitrous is a WOT and an activation switch I think. It wouldnt be possible to use in 1st and maybe 2nd gear because of traction issues. Is the only way for me to remedy this to buy a window switch right?
Do I need to tune for the 50 and 75 shot or is retarding the timing enough?
