night pager caliper bracket / mkiii or mkiv or ~'96 ls400 caliper mounting dimensions
SideWinderGX
733
Syracuse, New York, United States
Looking to see if anyone has any info on the night pager brackets that aren't being made any more. Want to bolt the '96 LS400 front brakes/calipers up to the mkiii hub.
If the night pager bracket was already made and someone has a set/has dimensions, that'd be great.
Otherwise, if anyone had any dimensions for the caliper mounting bolts for either the MKIII knuckle or the LS400/MKIV Supra knuckle (both are the same) that'd be great.
Thanks!
sthmstr
219
Colorado
I have been researching all the kits Nightpager sells lately trying to make one of my own.
I believe this is what you're talking about:
http://night-pager.com/cn6/cn9/pg111.html
From what I know they are just some kind of insert that you press into the caliper holes, that offset the mounting points lsightly so they line up with the mk3 hub holes.
I decided to meke my own version of his LS430 swap. Hope to have my set going int he next month. WIll poist on board once prototypes are done.
