NGK Powerdex AFX-Air Fuel Ratio Monitor
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
crazysupra2JZ
740
Georgia
blk92suprat;1149927 said:
Has anyone used this wideband air/fuel ratio monitor?
How well does it work? How accurate is it? I heard the display may react slowly?
I am between NGK or the AEM UEGO and leaning towards NGK.
I would like to get some feedback before I order one.
All I found was this...
http://www.supramania.com/forums/showthread.php?t=42641&highlight=NGK+Powerdex
And 1 or 2 post here...
http://www.supramania.com/forums/showthread.php?t=38112&highlight=NGK+Powerdex
Thanks guys
i love the NGK wideband. i have it now and it works great. it updates pretty quick and is very easy to calibrate. installation is very easy as well. this is the second one i have used. i had it in my 87 that i sold. the display is a little bright though, at night it can be distracting. but during the day, is very asy to read. it also shows you from 9 all the way to 16 afr's. i think most of them only display as low as 10. i'm not sure.
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
IJ.;1149981 said:
Had mine for a few years now and have compared it to a few high end MoTeC PLM's on various dyno's and it's always spot on. (actually more accurate than the M800 WB ;) )
Sounds good!
IJ....I read in the forum that you keep your Sensor connected all the time.
How long have you had yours or have you had to replace it?
I checked out the online manual and it reports a decreased lifespan if connected 24/7.
I do plan keeping the sensor connected so I can keep tabs of the A/F ratio all the time.
I wouldn't want to spend 120 bucks on a replacement sensor though.
Thanks again
figgie
Twin Cities, Minnesot-ah
blk92suprat;1150234 said:
Sounds good!
Thanks again
Not for anything but every single new vehicle in the US, has a wideband or two connected to the engine. They are connected 24/7 ;)
Usually based on the Bosch LSU 4.2 and some newer cars carry the Bosch LSU 4.9.
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
1 more thing....
Where did you mount your display?
Im thinking about the steering wheel column as the center dash area is filled with other goodies.
Any pics are appreciated!
LSU 4.2's x2 here in use 24/7 for 2+ years now on the same sensors :)
1 carbon'd up a bit during the LPG fuel system development and was throwing an error (reading stoich at all times) I burnt it off with the Oxy torch and it's been fine since.
I mounted the display in the AC vent closest to the dash above the AC controls.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I killed a sensor in about a year. It finally died when trying to tune my friends car... the car was in safemode the sensor was all fouled up from 9.XX AFR's.
I'll have to try IJ's trick with the O Torch :)
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
so IJ, would you give this product your "stamp of approval"???
i've been debating between the titan (innovative) and the AEM... but then i saw this on a site, and it caught my attention.
gaboonviper85
3,236
Northeast Philly
from what I gather about IJ is, "if he doesn't break it in the first 10min then it's a pretty damn good product!"...
That's just what I gather from his "trial and error" stories..
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
true that... if IJ cant break it, then you know somebody did there job! and if its lasted 2 years!!! goddd damn! they did something really right.
