Hi everyone. I've just installed the MAFT set up. Vehicle starts ok when cold
but is hard to start when warm. I did some research and see that Grim has the same problem if his climate control is left on when starting. Climate control doesn't seem to make a difference in my case, only whether the vehicle is hot or cold. I was just wondering if this was a normal side effect of the MAFT set up or if i've wired it wrong? Here are my settings:
AUX: 0
BASE: 2
IDLE: 0
MID: 0
WOT:0
MODE 1, 2, 3 & 4: OFF.
Also it doesn't make a difference if MODE 3 is on/off.
Thanks.
AUX: 0
BASE: 2
IDLE: 0
MID: 0
WOT:0
Thanks.
