I just got done finishing a bhg, tune up ,and new turbo. The car idles around 600 and runs fine, but im not getting any boost and it feels like a N/A.
red90turbo;1665482 said:On the boost gauge it shows 0psi when idling and when i start to go it drops down -4psi and then goes back up to 0psi. I havent put more than 5 miles on the car and i didnt want to push it too far. I havent had time to check engine codes so far but i will this weekend.
IBoughtASupra;1665490 said:You should have 17-22HG for your vaccum reading at idle. If not, you have a major leak in your intercooler piping, intake manifold gaskets or your accordian hose....
bikerdude198;1665722 said:a trick i use with snowmobiles to find intake leaks, carefully spray a little ether ( usually known as quick start or liquid fire, available at most auto parts stores ) around and listen, the idle speed will change when you find the leak. Might want to put on safety gogles when working with ether around a running engine.
