Hi everyone
i just bought a 88 jdm turbo 7m-gte 5 speed 91k miles on motor 181k miles on body the PROBLEM is FUEL CUT!!!:cry: i bought the car running 10PSI
stock TUrbo stock AFM stock Injectors .. so i got a MBC to turn it down maybe that would fix the Fuel Cut but noo
Mods
1.3in exhaust
2.Turbo xs BOV
3.Turbo XS Boost Controller
4.K&N [round Filter] [stock intake pipes]
5.Boost Gauge[reads vacuum]
6.Walbro 25 fuel Pump
7. HKS Metal Head Gasket
8.ARP Bolts
NO Check Engine light:icon_bigg
NO Power Steering
NO Charcoal Canister
NO Cat Converters
the BOV is TIGHT %100 so its not leaking
THe intercooler pipes are all TIGHT no Leaks
New Coolant/Hoses/Thermostat
NEw Spark wires/PLugs
NEw OIL/Filter
93octane IT's Entire LIFE
-----my boost/vacuum gauge at idle says 20lbs of Vacuum sometimes it says 19lbs im not sure why is changes
----- the idle is high at 1,300 :nono: [ im guessing cuz of the vented BOV]
----WOT on 1st gear i think it reads like 7psi when i shirt to 2nd WOT it fuel cuts at around 4RPMs
--- every gear minus 1st gear i cant WOT only like half on the pedal which is very retard i dunno :nono:
Conclusion: i cant Run WOT 2nd-5th gear cuz of fuel cut the check engine light turns on when it hits fuel cut and 5 seconds later it turns off
-----------I NEED HELP im NEW To SUPRAs//TURBo"S
Mods
1.3in exhaust
2.Turbo xs BOV
8.ARP Bolts
NO Power Steering
NO Cat Converters
NEw OIL/Filter
