New Supra Help for the Inexperienced
Dec 20, 2007
94
El Sobrante, CA
Ok, so I just bought a 1987 Targa Turbo 5 speed. There is 217,000 miles on the car. The guy said he just replaced all the gaskets. Should I do anything else (engine wise) to the car before I start putting aftermarket parts on it? Like, should I have the block rebuilt or anything? There are no leaks or funny sounds but I don't want start building it and then the car falls through. Help me out here
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
the guy that i bought mine off said the same thing and turns out only 1 gasket had been replaced haha. just check compression and ur rad for compression or sludge hmmm personally i'd take a look at the torque on the head don't want that coming lose when ur doin upgrades :D
Dec 20, 2007
94
El Sobrante, CA
supra_kid101;898241 said:
I'd do a compression test first. Thats a lot of miles and personally i'd rebuild before anything else. What exactly are you wanting to do to it performance wise?
I plan on building it to somewhere between 400-500 horsepower. I want it to be my daily driver but still really ballzy!
NocturnalKitty
116
Ca/Az
that is a lot of miles. i'm w/supra kid...rebuild. the guy said he replaced gaskets....but did he do the hg? u will need a mhg and arp head studs and it would be a good idea to do a full rebuild especially at that mileage and considering ur hp goals, age of vehicle, etc (wear and tear over the yrs). good luck
Dec 20, 2007
94
El Sobrante, CA
he replaced the headgasket also. Im just concerned about the internals with this many miles on it
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
you told me the engine was fully rebuilt
you might want to properly advertise your car so people don't think your tryin to jerk them around
Dec 20, 2007
94
El Sobrante, CA
Nomad707;898551 said:
k sorry..
When did u get the turbo?
did u trade for yer car??? fill me in.
Someone's planning on buying mine this weekend. And I changed the car Im getting also. Im getting a 1991 turbo supra. It has a blown headgasket but moe is gona help me fix it. Here's the specs on it....
-139k miles on it
- Port and polished head with only 10K on it,
- Competition valve job
- 2nd Stage gripforce clutch (less than 5K)
- JDM Competition flywheel with (less than 5K)
- K and N intake
- Huge aftermarket FMIC
- Faze A pillar (wide band air/fuel, Boost gauges)
- BIC Widemouth divorced wastegate downpipe
- HKS blow-off
- HKS Hi- Power Muffler
- 1 pc. Custom 3" mandrel bent racing back exhaust
- New Hi-Flow TRD water pump.
- 18X9 Ultralite Shuk Racing Wheels
- 4- good Kumho Z rated tires
RiyadYar
384
NY
i would reccommend you do a compression test, and a basic tune up. change all fluids, spark plugs, spark plug wires etc.
