I run Autolite Platinums, $5.96 full retail. You can get them cheaper. I ran non-platinums for a while, no problems, but platinums will last 3x longer. So you don't have to do the change-out as often. Iridiums are too $$$ for the spark.
We only use Autolite at the shop, as we have seen different types of problems with other brands. We NEVER use Bosch, seen too many problems over the years.
Also...if you use an MSD ignition box, do NOT use regular plugs, as the multiple sparks will wear them out in a hurry.
And...do NOT pull out the plugs when the engine is hot (warm is ok), as the threads in the head may want to come out too. Put a squirt of lube spray on the new plugs threads first.
When I was moto-crossing (Yamaha & Hondas) I tried all kinds of plugs. A 2-stroke MX bike will really let you know if a plug is any good. I ended up running Nippon- Denso's with the 'fireball groove' in the ground electrode because they did NOT foul out.
PS. 2-strokes have oil mixed with the gas, so they might foul out in the most inconvient times.
