New electric fan option...
gixxer750
2jzget comingsoon!
Mississippi
won't work...they are three inches too wide, and 1.5 inches too tall....I will find something else. The Fan control temp sensor works nicely though, my electric fans run all the time in town, and none on the highway....
Now to do something about my slipping clutch...
figgie
Twin Cities, Minnesot-ah
three inches to wide for the stock radiator?
i know there is roughly about 34 inches between the frame. The ultimate question is does it fit in the engine bay at all? If it does. Three inches can be made to fit ;)
gixxer750
2jzget comingsoon!
Mississippi
yes, it will fit in the engine bay, but it will hit my hardpipe going through the snorkel hole....I'm going to find a different route
keo
153
RI
what are the measurements? Im thinking of changing to e-fans also.
& pics toooooooooooooooo
williamb82
907
4
Tampa, Fl.
how much air does the dual electric fans from a 95 ford contour v6 flow? i plan to run those and was just curious since you seem to have found a site to check for that info.
gixxer750
2jzget comingsoon!
Mississippi
didn't take any pics.....just held it up and looked. It will fit between the frame rails, but if you have a koyo radiator, it WILL be a tight fit between the fans and your pulleys on the front of the motor....maybe an inch and a half clearance.
Eriol
Indianapolis
Blah!
"We do not have this information on file due to the fact that they are
manufactured for direct OE replacements. I apologize for any
inconvience this has caused. Have a great day!"
:mad:
So I guess the only way to know for sure would be to measure it ourselves, or possibly find a way to get the CFM rating of the OEM unit that this part replaces.
I still give props to Gixxer for finding something new and interesting to try, though.
Adjuster
I've read that Ford Taurus two speed fans are very good for the Supra. (MK4 guy swears by his setup.)
That being said, everyone who runs the car hard, and runs full AC in traffic with E fans has had problems from what I've read. (Check it out on the MK4 guys.) The stock fan setup with a good fan clutch is pretty much bullet proof, and it's cheap since you already own it.....
Just a thought.
I'd like the E fan(s), but I'm not willing to take the time to develop a setup that will cool the engine in any weather/use.
chevyeater
wastegate hose is pulled
Long Island, NY
Those Impala fans suck down a crapload of juice at full honk anyway. They are run @ 3 speeds in the OEM app, controlled by a load manager and powered by an alternator that can output 96A at 600 engine RPM.
