New electric fan option...
gixxer750
2jzget comingsoon!
Mississippi
I think I may have found a very nice electric fan setup for the supra, similar to a FAL setup, but much cheaper. I am ditching my current setup of two parts store fans for this, and I will let you know how it works out....
The two fans I have now, the conbined airflow is about 2000cfm, the new setup pulls less current, looks much nicer, and has an airflow of 4500 cfm. Also, it is a dual fan setup and has a single nice looking shroud. The fans are from a 2002 chevy impala police interceptor. The size looks about right, I will know for sure tommorow.
Part number for the dual electric fan is 620629 at advance auto parts. Cost is 152.88 Here is a picture. The setup comes with a lifetime warranty.
I also plan on using a fan switch on this. I will be using a stock radiator fan switch from something(don't know what, found it in a book). The part number for it is 405039 also at advance auto. This is a two terminal fan switch that will thread in one of the temp sending holes. The fan cut on temp is 200 and will turn back off when the coolant temp reaches 190.
I am running a 180 thermostat and a koyo radiator, so the fans running all the time shouldn't happen. This setup appears as though it will work quite well. I do not have a problem with the fans I have now...they work great, but I can get my money back on them from advance along with the money for the control thermostat for them, and it will pay for this newer much nicer setup with a lifetime warranty.
What do you guys think about this?
gixxer750
2jzget comingsoon!
Mississippi
well, these aren't aftermarket fans....I had to do some research to find out the ratings on these things. Like I said, these are stock police package impala fans. The should be fine to cool our cars off, even better with a koyo or flyudine radiator...
at 4500cfm they should be fine Gixx!
I think I read somewhere that's what our engine fans are rated at.
Most aftermarket fans aren't even close to this so don't do a great job.
gixxer750
2jzget comingsoon!
Mississippi
I do know that it is much much nicer looking than my current electric fan setup....got the cords that run through the radiator with the springs holding them on. I've got wires run everywhere and the fans are two different sizes...
figgie
Twin Cities, Minnesot-ah
well dual 12 you are correct
the dual 13 pull that about 2700 70% and upwards of 4k cfm when running at 100%. Check the Fluidyne 295
http://www.flex-a-lite.com/auto/html/27inch-electric.html
figgie
at 159 is cheap...
at 4500 cfm.. man this would kill the FALs :)
Idealsupra
Orlando
www.tampabaysupras.com
if anyone can actually confirm the cfm rating on those.... im in for sure! especially since i have a hookup at advance :D
AWESOME find! i didnt want electric fans because of the fact im in FL and i didnt want to pull less cfm and risk problems...
i need to verify thatcfm and then its game on!
post up pics and progress mang!
gixxer750
2jzget comingsoon!
Mississippi
no, I'm sleeping late today, because I've been getting 5 hours of sleep every day this week....I'm about to go pick them up and install now :p
