First, the reason I'm posting it in tech department is I have a question to ask after I post my new dyno numbers. I will try and scan the dyno pictures when I get back in tonight, but here are my new dyno results.
Max. Torque= 379.1
Max. Power= 406.3
I only did two dyno pulls, because on the second one I saw antifreeze come out of my radiator cap, and since I'm a chicken shit, I didn't do any more pulls. I was also happy with the 406. The first pull was
Max. Torque= 384.2
Max. Power= 392.0
When I post the pictures up, I want someone to tell me if you agree with Blake, the man tuning it. He saids that he thinks my wastegate is getting stuck open. He showed me a dyno pull from another supra, and it looked different than mine. He said mine looked like a naturally aspirated dyno,cause it was a steady pull all the way to 406. Most turbo cars he said should climb faster and then level off. Mine never quit pulling, and it took a while to get there.
I don't have a bc on my car right now, and I was boosting up to 18 psi. That's another reason I didn't do another pull. That is more boost than I felt comfortable with. I went by the shop that built my turbo and he agreed with Blake. He thinks the wastegate is getting stuck open also. My wastegate is supposed to be set at 14 psi. I don't really know that much about turbos, but I know that's what he told me when I had it built.....................lol
Edit: I just put the dyno sheets on here. The first one is a comparison of now and the one I did back in March. You can see how the same turbo runs totally different. The other three are from today.
Max. Torque= 379.1
Max. Power= 406.3
Max. Torque= 384.2
Max. Power= 392.0
