Ok guys I have an 87 Supra with a 1JZ swap and a single turbo. I had a starting problem and decided to take the intake off to clean it and inspect it. I didn't get too far until I found out you have to disconnect about 75% of the harness. So I put it back together and just changed the plugs and bam it started right up. The car runs fine but won't charge up. I took the old alternator off and had it tested. It was bad so I bought a new one and installed it and the same thing is happening. The car had no problems before i tried to take the intake off. I have triple checked all the wires and have only found 2 that are possibly the problem one is a single black wire that looks to connect to the starter, but the problem is I don't see were it would and the second one is a rectangular box with 2 big yellow resistors on it. Only one side is connected, but I can't find any other connector that would work for the other side. I hope this is enough info and some one can help me out. Thanks
