So, here is the story. I started this build thread and I was enjoing this build. I built the bottom end with it being cut ten thou and having new bearings, mains, rods and thrust.
I sent the head to a machine shop that my Dad used for our shop and that was all fine. We got back the head and everything seemed fine and I did not check it since we paid 800 for a rebuild and three angle valve job.
So we assembled the engine and then it was off to starting it. We had a few issues with vaccum leaks and codes, mainly code 51. After those problems were fixed, the car would not idle, it would keep moving up and down between 500RPM and 1000RPM and then eventually stall out. We even cleaned and tried a different idle valve and it did not help either.
There was a rattle in the head like a bunch of marbles were loose, so I did my research on here, getting flamed a lot, since I was just learning these things for myself and helping a mechanic build my engine. So now I was learning what the shims were. With the help of my mechanic, I took a fresh head of a new Supra(More On That Just Now) we bought and went to work. I took the head to a different machine shop to only have it checked for straightness, decked and hot tanked.
After that, I bought a Saftey Gasket set and then I replaced the valve seals, seated the valves, check for leaks with gas in the ports and then did the clearance. I bought the shims from GoodSon Engine Builders and used the Excel worksheet that was on the forums(Thanks To Who Made That) to calculate the new shim sizes. I had to grind some of the shims I bought as well. I made all the clearances back to factory specs, eight thou and ten thou on the intake and exhaust sides.
I bought a new Supra, a Red 1989 Targa Top Turbo Supra. This car was so clean and I got it from the guy for $1,400. He got it for a birthday present and then I got it for my birthday present. The engine siezed up and he had it covered in his backyard for two years until I bought it. The car's paint is in excellent condition as well as for the interior. The stock tape player is still in there!
After that we put together a new engine, honed with new rings and bearings, and with the head built buy me, we started everything up this past Saturday and it is running, but I did not have in a few vaccum lines and the line for the idle control valve, so it did not idle. We just wanted to start it and hear for any knocks and rattles. None!
Pictures:
WHAT IS THIS PLUG FOR UNDER THE FUSE BOX?
WHAT IS THIS PLUG FOR UNDER THE DASH? ALL THE PLUGS ARE PLUGGED INTO THE HARNESS THOUGH.
The only thing that I am left to do is get the radiator and fan shroud kit from Grimta, reposition my turbo, and then run all the vaccum lines. Then install some small parts like stainless steel hoses from DriftMotion for the clutch line.
Things To Do:
-Install Radiator And Fan Kit
-Install Full Flow Oil System
-Install Clutch Hose
-Install Intercooler Piping And Reposition The Turbo, Make New Turbing For That
-Install Vaccum Hoses For The Engine/Wastegate/Gauges
-Install Gauges
-Break In
TEST DRIVE!
Pictures Of The Car, The Hood Was Open In Those Two Pictures.
