So here's the deal. I'm going to be posting updates whenever I can BUT due to not having a job at the moment things are going to go very slow so please don't expect frequent updates
History
So i bought this car knowing that it had several rather large issues but since i'm restoring the car with new, aftermarket and upgraded parts I did not really care that it did not run. So far i have found that the engine has a BHG and numerous electrical issues, the rear end fluid has rather large metal shavings in it and the interior wiring is all hacked up. Body wise I couldn't be happier especially since here in the Maritimes everything turns to rust and falls apart rather quickly but this car barely has a spot of rust on it. The only thing wrong with the body is the busted trim and old paint.
Phase 1: Tear down
The engine is almost ready to come out, just waiting for space in the garage to pull it.
The dashboard has been removed.
The entire interior is coming out hopefully tomorrow.
Both engine and body wiring harnesses will be removed and repaired.
Everything is coming off the car at some point to be cleaned, repaired, powder coated or upgraded.
More to come tommorow
History
Phase 1: Tear down
