This should be a pinout for my jza70.
I need to know which wire is for the tach, for a remote start system. IGF I think? Also how to test for an output for the tach off the computer ?
Also throwing a code 12
-No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked
I am 99% sure that it is a wiring issue under the dash, which wires should I be checking? I think it is connector U the Cam sensors, but what do I check them for? Voltage, continuity to ground, ?
Also could someone please tell me why the cam sensors are both listed twice on that same connector U ?
Thanks alot.
If you have any ideas where I could find such information please please link me!
***Found the problem. Look below for an update***
Thanks alot.
