Need ways to reduce weight in my poopra
89Turbo
804
Portland
keep in mind that it will still be a daily driver and need to be somewhat comfortable i am not going all out racing.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
hmmm. i like the seats, and the ac, lol any thoughts on lighter wheels , like magnesium? or whats the lightest?
pros or cons?
mkIIIman089
Ohio
If you have the money... I'd grab some of those magnesium Volk TE37s. They are insanly light, but like over 1000 per wheel.
jam4484
MKIII Lover
Jul 24, 2005
135
Tolland CT
You can go for fd wheels or mkiv wheels because I am pretty sure almost anything is lighter than sawblades. Lighter wheels are nice because the lighter they are, the less force it takes to turn them, etc.
Jon
Charlie97L
230
Clarksburg, MD
wheels are good weight reduction, but as unspring weight, not really what he's asking about.
our front seats, while comfy, are probably the biggest freakin weight gain on the car. it's like the seats in my gt4, they were like 70+ pounds each. Comfy as hell, but a nightmare in weight.
Carpet is big too, but the ladies like carpet, so that's staying in mine. :)
mkiii222
Troy, MI
Drilled rotors/lighter rims(there is debate about drilled rotors lasting, but I've run them on a 95 Celica for 80k with no cracking and MANY 100+mph stops).
Sound deadening under carpet(tough job, but will net 20+ lbs of 'tar').
EGR(depending on emissions testing, in TN they don't even check under the hood, but some places are more anal).
Exhaust system(most anything is lighter than stock).
Charcoal canister(only a couple lbs, but it adds up).
Aftermarket stereo(my Kenwood CD player easily weighs 1/2 of the factory tape deck, speakers are generally heavier aftermarket though).
And if you're real crazy about weight, lightweight nuts and bolts.
b005t3d
505
bellevue,nashville, tn
strip all the uneccessary little motors and actuators, like for the mirrors and the antenna. tow hooks, all ac shit. by the way, i had all of my ac stuff out for the entire summer in south carolina. it sucked but at least the weight was off.
supraman7mgte
Shut up,bitch!!
Sunny California
Replace the hood w/ a carbon fiber one.If you can find a decent one w/ no cracks!Get a donut spare,there is alot you can remove,but it might not add up to much,you will still have a heavy car,it just goes with it.
89Turbo
804
Portland
i replaced the stock spare with a AAA card, i am contemplating ditching the back seats and back seat belts, i will have a new 4" stainless steel exhaust in a couple of months.
about the EGR is that actually going to affect the muffler part of the emissions or just the visual, because here they dont do visual.
the charcoal canisters' purpose is??
front seats i plan on doing eventually
if i take out the antenna and its motor what am i supposed to do with the hole in the body? weld it up?
i was thinking about removing the 3 piece wing but it looks at though the hatch on my car is not the original and the wing is barely holding on, the hatch that is on there now has gaping odd shaped holes in it that i would need to patch up, how should i go about closing these? welding or bondo......
can any glass place replace my rear hatch glass with plexiglass/lexan?
thanks for all the quick input:icon_bigg
jtamulis
www.NotRice.com
Apr 9, 2005
537
Pittsboro, NC
www.NotRice.com
IJ. said:
Buy a Mk2 and swap your drivetrain into it......
Seriously you're starting with the wrong car if you want light weight, it's a GT not a sportscar.....
For the record, I used to have a 454rwhp 1990 Supra Turbo, 5-speed.
the car was near mint.
I have said it before and I'll say it again:
"I took _ONE_ ride in Chris Parvin's 7M-GTE powered MKII Supra that I helped
him build and I started taking my MKIII Apart to build one."
Since then I have built several 7M-GTE MKIIs, and my 1984 has 350+rwhp
and I've never looked back... Ever.
Lose 850lbs of weight by switching to a MKII body. And you can keep the
A/C, sound deadening, facotry seats, etc.
