i was driving down the road this morning and i started to hear this knocking sound. kinda a tap tap tap when it is in idle then i rev it to about 2-2500 rpm and it sounds like a second tap starts up and this one is way more violent and way louder. it was the same in every gear. and if i let off the throttle at all it would instantly stall even if i was in gear and moving. i checked the oil and i had oil. it was a little low but not below the empty on the dip stick. i toped up the oil and started it back up and it still has the tap tap tap. i reved it at it still does the faster louder tap. the tapping is very rappid and sounds like its coming from the center of the engine.
any ideas?
Thanks
Travis
ps: its a 7m gte with 183 000 km on it. it has some work done to it. aftermarket turbo and turbo manifold, fuel pump and injectors. i have a dual stage boost controller and the one stage is boosting at 6psi and the other at 14 psi. i rarely boost it at 14 psi but yesterday night i did tho the first three gears and it didnt sound like anything was wrong.
any ideas?
Thanks
Travis
