Need some help with programming Peak Prosport Gauges
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
I tried removing the toggle switch we connected for the color change, but no luck. Tomorrow when Shaeff comes over, we're gonna look for a new power source and hopefully get it right. Not to mention I think my heater core is leaking. This is starting to get depressing. It really never ends.....
Mo
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
i just bought one of their oil pressure gauges and i get the same thing but heres their faq on setting the warning
Q: How do I set the warning levels on my Premium Series Guages?
A: To reset the memory: Push and hold the button until the pointer begins to flash. Release button. Then while the pointer is still flashing (set mode) push the button and hold it to move the pointer fast or each time you push the button the pointer will move in small increments to the exact point where you want to set it. After you have the pointer where you want to set your warning level just wait about 6 seconds and the pointer will stop flashing and retain that point as your new warning level. If you pass the point you wanted to set the level at-just keep going and once it reaches the end of the scale it will begin to come back
