Need some Help... First Supra...
AIRRMark
Jackson,Tn
:1zhelp: I NEED HELP! I bought an 86.5 Supra with the 7mge n/a and it needed A tranny. So I bought one out of a 1991 Turbo 7mge (automatic) and everything Swapped out fine.. so Everything is Together and The starter won't turn over...? What did I do Wrong Or what Do I need To Check...? Thanks to any one who could help
radiod
1,342
Abbotsford, BC
Check connections and fuses. You have power to the rest of the car when the key is in the "on" position? Check for voltage at the starter solenoid signal wire (small single wire that clips in to the starter, not bolts on) to see if that's getting power when turning the key to "start".
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
Does the starter click or make any noise? If so just remove it and take it to have it checked. If not there is a power issue. This shouldn't be a serious problem to fix.
