need help
IHI-RHC7
"The Boss"
Oregon
Actually, the injectors are powered directly off of the AM2 fuse, so removing that fuse would also render the ecu powerless, so it wouldn't start with the spray..
The only way to kill them is to unplug the EFI resistor, which has a big round 4 pin connector on the left fender. ;)
For sure!
If you work one step at a time and something goes wrong it's usually the last thing you touched! ;)
Makes it easier to backtrack and fix things this way as opposed to making a bunch of changes and not knowing which one caused the problem!
bandit
supra enthusiast
May 16, 2005
76
southeast missouri
well i just went out there and looked and i only found one 4 pin plug ,but its under the steering shaft, plus the battery is down so much from tryin to start it that its dead,damned da luck!
bandit
supra enthusiast
May 16, 2005
76
southeast missouri
i still dont see it i looked all over i guess im blind. only one i see is under the steering shaft. can some one post a pic?
IHI-RHC7
"The Boss"
Oregon
ok, it's E2 in the following image...
