I'm not sure...because it depends on how its installed.
If you have the "male and female" quick disconnect plugs on your ignition harness.... it should be easy, but if its all soldered its allot more work.
You can see the emanage manual drawing states "Male" and "Female" connectors at each end of the ignition harness..... so it would be easy to go back to stock configuration. But many has probably soldered those connections instead, leaving you stuck with "adding" temporary jumper-wires in the emanage plug until you have found the problem.
Jumperwire everything back to stock...all the aftermarket ecu's just fuck up everything on a stock ecu.
