I'm having some real trouble with these studs because I don't know what to do. I have ARP Head Studs. My friend is telling me that you have to torque the studs into the block, then the head and washers, then the nut, and then you torque. I've read numerous threads on doing the HG, and I haven't seen one that says you torque the studs into the block.
He used ARP Undercut studs on his.
Can someone please tell me the difference between regular ARP studs, and the ARP Undercut studs. I really don't understand.
I am doing the job according to this:
http://www.supramania.com/forums/showthread.php?t=38956
It doesn't mention torqueing the studs into the block. It says to lay your gasket first, line up everything, slide the head on and line up the holes. Then apply the moly lube to both sides of the stud, and insert the stud with the washer down through the head and into the block.
I thought you didn't need to torque the studs into the block, I just thought they were supposed to be finger tight.
Everyone who knows something on this topic, please help.
-Ryan
-Ryan
