Need help with knock sensor rewire..
WillWorkFoBoost
that guy
Sep 1, 2009
130
Maine
what coax cable did people use to do this? I rewired it with rg6 and I seem to still have heatsoaking or something in the wiring,phantom knocks on the safc after excessive driving.
thanks
jonahs_supra
1,015
Lancaster, Ohio, United States
i just went to radio shack and bought a roll of shielded wire
only shielded wire they had available at the time was something like this
http://www.sesystems.com/West-Penn-...=google&utm_medium=Base&utm_campaign=Products
instead of having 1 wire that is shielded i have 2 wires and then the shield
so what i did was use both wires for 1 knock sensor
then did the back knock sensor with another length of wire
grounded my shielded wires on to a (fresh metal)clean ground on drivers side strut tower
did this about 6 months ago(7,000 miles)
still holding up great with no code 52
my back knock sensor plug was busted...so i just used a femal spade connector
but last night i put on a new connector
never had problems from the spade connector though
TweeT91109
738
Tampa, Florida, United States
Pictures would help a lot of people understand.
Skeezix
Supradope
Dec 30, 2009
229
Regina, SK
Just about to do this on my car and just one thing to clear up. Running a turbo here so I have two sensors to wire, ground both of them right? I'm going to ground at ECU just making sure I should ground both wires.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
the stock sencores is grounded to the ecu it's best to ground there easy way to test this is pull back the sheeting and then do a beep test ei or restaince test you can even move the harness around in the intake manifold whail testing
if it works put a new plug on and call it a day, if the plug is busted a female spade connector crimped on the end will do
alot of people treat this like the Hubble space shuttle when it really is not
plus the only one that is sheilded all the way to the plug is the starter aka the farther back one
