Hi,
I'm not quite understanding the knock sensor rewire guides..
First of all, one guide says to ground both sides of the new cables, the two other guides says not to, and one of them points out that it will just create more noise then no shielding at all. What's correct?
Also, it would be great if someone could explain in an easy way how to connect the new wire on the ECU connectors. There are lots of words I don't fully understand in the guides, which makes it hard to know what to do. Are the old cables on ECU pins only going to the knock sensors? Is it then to just cut the old cable(not too close to ECU) and then connect the new cable to it?
Does it matter which knock sensor leading to what ECU pin? of those two..
Where is the "ballast resistor at left strut tower"? Can I just connect it to the intake plenum where it's already got some grounded cables?
http://www.supras.com/06/techcenter/display.php?QID=51
http://www.supras.com/06/techcenter/display.php?QID=69
http://oldschool.supracentral.com/htm/knock.htm
