need help with cooling
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
benchwarmer;1192893 said:
I think that thermostat is too cold. You're probably running rich.
OEM is like 190? but yeah, he is wasting fuel...
i would check the thermostat, and also check the rad cap.
pressurize the system and see if you have any leaks that only show up under high pressure.
oldcoopdog
camp pendalton
tsparks01;1192757 said:
i had a similar problem,
1; my thermostat was rusted shut due to mixing 50/50 coolant and water
2; solution---, i bought a 160 degree thermostat with new seal, this thermostae opens early and keeps the open till the temp is leveled or lower
3; i emptyed out and flushed the radiator, jacked up the car in the back and purged the block, i completely washed out all the shit that was in there and when i was done i want and got some prestein all antifascist and fulled her up and from then on there she never did again, and if that dosent work and u dont have any leak, well then it might be ur head, and if it is, i wld pull that motor out and swap for a jdm 1.....
this one is a jdm one and ive tryed three rad caps and 2 thermastats.
supramk3turbo
53
Norway
I had the same problem with my mk3 2jz-gte. The problem was the head gasket, it leaked exhaust to cooling water. So with slow driving it was "okey", but on a little boost she got hot just like that. Try to measure CO in your cooling water, if there is any, problem found:icon_bigg
