There better be two if that thing is meant to go in a rad hose. If only one you need to ground the sensor body. Same when testing but that should have been intuitively obvious...
jetjock;1069338 said:There better be two if that thing is meant to go in a rad hose. If only one you need to ground the sensor body. Same when testing but that should have been intuitively obvious...
jetjock;1069366 said:I was impressed by the anodization call out![]()
