Need help!!! Walbro Pump and my shitty wiring! 2jzgte swap relies on this!!!!!
SupraMario
I think it was the google
The Farm
IJ.;1110581 said:
QuickNeasy "fix" would be to use an LPG safety switch.
It watches for RPM if there's none it shuts the power off.
O.O that sounds like an awesome thing! Cause then it won't run when the car is in the ON position but not starting! YAY
So where is a good place to buy one? And how much are they? And where would I wire it too?
You could wire it between the line you have from the ECU to the Fuel pump relay then all it needs is a rpm signal.
(This is how the stock ECU acts normally)
I guess anywhere that Supplies/Fits LPG/Propane systems for RV's/cars/trucks?
Not real expensive.
I have a couple here but you need one now I guess?
SupraMario
The Farm
Not real expensive.
No don't need one now, as this car is going to Cookeville and then going under the knife again to make sure everything is running %100.
SupraMario
The Farm
IJ.;1110615 said:
Haven't read through the whole thread but why can't the 2J ecu control the pump as normal?
It can...but I didn't do the wiring, doc did. He did a switch though, basically instead of the wiring going to the ECU he left it bare and told me to wire a switch to it so I did. Turn the switch on...power to fuel pump, turn it off and no power, but when I leave the switch on, and turn the ignition to on and not start, the pump runs. So basically it turns on without the engine being started.
jdub
Feb 10, 2006
10,730
Valley of the Sun
jetjock;1110602 said:
An inertia switch is also commonly used for this.
I believe the Ford Crowne Victoria uses these ;)
Ian - wondering the same thing myself.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I believe the Crown Vic does. So do many older Ford trucks and Jags, among others. So do Deloreans and ELTs ;)
Also known as a Rolomite Switch. Basically a steel ball held in place by a magnet that when dislodged in a collision opens a set of contacts. And yeah, it's bad news not having at least something...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yep...a weenie roast waiting to happen.
LOL...sudden stops do activate an ELT!
I was thinking about using one of these inertia switches in the rear of the car as an added measure.
SupraMario
The Farm
Yea I know, believe me I am the first person to scold people when they do stupid unsafe shit.
Just hope this one time doesn't get me killed that I break my own rules.
jdub
Feb 10, 2006
10,730
Valley of the Sun
LOL...Guard is hardwired on (at least on the jets I flew). Lets say an ELT is highly irritating ;)
Mario - Emergency Locator Transmitter...transmits on UHF 243.0 and/or VHF 121.5...the new ones also on 406 MHz.
Dr Tweak
Hey guys,
Of course there's a reason for the FC circuit not being connected to the computer: this is a 2JZGTE ECU, which DOES NOT HAVE AN FC CIRCUIT.
The 2JZGTE actually communicates with another ECU, called the fuel pump ECU (which replaced the C/OPN relay). Since no one that I know of has ever installed the said Fuel Pump ECU into their car when doing a 2JZ swap, the only way to turn the fuel pump on is with a switch running to the stock relay.
FP (the wire going to the ECU which switches between high and low voltage) is also not used by the 2JZGTE ECU, which means that when the fuel pump is running, it's always in the default condition (high voltage). Thus, no bypass is needed.
THIS ONLY APPLIES TO THE 2JZ SWAP! :) Now if you want to do an easy bypass on the stock ECU, just cut the yellow FP (not FC!!!) wire, and the pump will always be running full voltage.
As far as safety, I do agree that it is best to have the fuel pump shut off when the engine is off, but the only way to do that would be to either 1. Locate and install a Toyota/Lexus Fuel Pump ECU or 2. Install a device like you guys were talking about (RPM activated relay). I'll have to look into that to see if I can pick some up to stock, I hadn't heard of them before. MSD has some RPM activated switches but they are $$$.
-Doc
jdub
Feb 10, 2006
10,730
Valley of the Sun
LOL...GOOD reason ;)
The MSD switches require a RPM module...I didn't see one at a low enough RPM to be useful.
