Aarons Stinger/Tach diagram calls for a 2.5k ohm, .25 or .50 watt resistor to make the stinger drive the tach. I've looked high and low, both on the Internet and locally, and haven't been able to find one. the only one I could find in 2.5k ohm is 25 watt.
Can I run a few that are in the correct wattage range in series to equal 2.5k ohms? The local radio shack guy said that it would work, but I don't trust his knowledge.
Thanks
Thanks
