need help - clutch pedal has no pressure (pics pg 2)
solardrgn
77
socal
problem - my clutch pedal does not return and stays all the way to the floor. i can move it almost freely with my hand.
i was in neutral slowing down for a red light, it turns green and when i pressed the clutch it goes all the way back and stays there. ive had no previous problems of anything like this and i didnt notice anything wrong with the clutch until that instant
anyone know what could be the problem or what i should look at? i tried searching and found nothing but i probably dont know what im looking for.
thanks
**update - if no one feels like reading it through
i took off the cover by the slave cylinder and the push rod of the slave cylinder disconnected. i found something with a notch where it looked like the push rod was supposed to go, which now hangs freely. a friend said my trans housing is messed up and possibly the clutch from it spinning?
what would be my best course of action now?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
You need to bleed it, there is air in the line. You said it randomly did it to you though, so I would check for leaks. Start at the master cylinder (look under the dash where the pedal push rod goes through, make sure there is no fluid dripping down), then go to the master cylinder in the engine bay and follow the line all the way down to the slave cylinder, make sure there are no leaks and that the reservoir is full. Go from there (bleed).
Late
125
Appleton, WI
this just happened when i installed everything in my car, was really confused why. the slave cylinder is on the bottom driver side of the tranny, slide under there you should see it pretty easy it has a line coming from the engine bay.
Late
125
Appleton, WI
There should be a little bleeder valve on it (nut with a nipple type thing on it), may or may not have a little piece of rubber over it. Depends if you have a w58 or r154 on what it looks like but both should be similar.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
There is a reservoir on the master cylinder, make sure it is full. Look for leaks along the line and master/slave cylinder. Fix leaks if you find them, then bleed.
solardrgn
77
socal
also, i just turned the car on to move it and there was a rattling sound that sounded like it was coming from the under the hood near the drivers side im guessing near the master/slave cylinders. i dont know if it has anything to do with it but i dont think it was there before. ill take a look at it later today when i have light if i can move it back but i just wanted to say thanks for your help so far!
solardrgn
77
socal
no leaks but i found my problem... im probably using the wrong terminology. i took off the cover by the slave cylinder and the push rod of the slave cylinder disconnected. i found something with a notch where it looked like the push rod was supposed to go, which now hangs freely. a friend said my trans housing is messed up and possibly the clutch from it spinning?
SC61 MK3
316
FL
prob have to replace the clutch slave cylinder, or fix the one you have. 2 bolts to remove it and it slides out
solardrgn
77
socal
theres nothing in the housing that could be messed up also? how does the slave cylinder attach to the transmission?
Pics? Yes there are other things that can fail, sounds like the snap ring on the hub failed (usually do to incorrect assembly).
Late
125
Appleton, WI
take off the plate on the transmission and youll be able to see if something isnt right, the slave cylinder should connect to the clutch fork and push it against the clutch. i had the issue where my slave cylinder missed the hole on my clutch fork and my pedal went to the floor with no pressure.
solardrgn
77
socal
ill have a pic tomorrow i hope. i took off that plate already, on the other page i said the push rod is attached to nothing. if its supposed to be attached to the clutch fork should the clutch fork be somewhat stationary. what i saw was hanging down very loosely. the transmission hasnt had any work done since 2000 according to the original owner and ive had it since 2008
solardrgn
77
socal
heres the pics. the slave's push rod is attached to nothing. and that piece of metal is completely f'ed... so what exaxtly broke??
