Bigdough666;1317745 said:Are you guys using the ATI adaptor kit to bolt the GM trans to the 7M?? what converter? What else do I need to swap a GM auto into the car? I can get a TH350 cheap and get it built pretty cheap as well, so what would I be looking at $$$ wise for the rest of the swap?? I have a built Toyota in it right now and Im already overpowering it, so I am lookin at the TH350 swap. Any help will be appreciated. Thanks guys.
i have the plate from shawn (besttrans) and running the precision converter.
if you still have the heater hardline on the backside of the motor, you will need to modify it. you can either modify the hardline (not easy with the motor in the car) or you can modify the bellhousing on the trans.
pic of mod'd adapter plate and hardline.
pic of mod'd bellhousing
