I need to purchase the mentioned above...
Now which Platinum NGK spark plugs to buy? I searched and saw a lot of part numbers and different types.. Any better than the other? part number would be appreciated! Also, wires part number would be nice
I searched for high flow cat and found the following:
http://www.suprasport.com/RT-High-Flow-Metallic-Substrate-Cat_p_54-17.html
http://suprastore.com/higflowcat3d.html
Any advantage one over the other?
Here is my new set up:
ARP head bolts
Titan MHG 2.0 mm
HKS Super Drager exhaust
HKS down pipe
Koyo OEM Radiator
Apexi Air Intake
driftmotion 57 trim Turbo
All above item are purchased BRAND new about 2 weeks ago
HKS SSQV BOV to be purchased next month
The boost will stay at stock levels... maybe 8 psi at highest.
Inputs are greatly appreciated.
Thanks
ARP head bolts
Titan MHG 2.0 mm
HKS down pipe
Koyo OEM Radiator
Apexi Air Intake
Thanks
