Need help asap!!
supra*13
massachussets
ok my car is an 86 supra 7mge converted auto in to a manual, it died on me at a parking lot a couple of weeks ago it sat for two weeks due to work i couldnt work on it. a week ago i stared working on it andi needed to removed the intake manifold to fix the knock sensor. i put it all back together and took the distributer out and not i get no spark i really need to get it goin so i can start working as a delivery man
Mondo
132
Wisconsin
Check your timing?
Not positive, but on my Celicas atleast, if you didnt put the distro back in the same exact position your firing will be off.
Make sure you are getting spark. Take out a plug, ground the threads to the block, have a friend turn it over and see if it sparks. Do this for each wire, just use the same plug.
supra*13
massachussets
i already did, i even put the number 1 cylinder at tdc and put the piston at number 1 wire,i checked from spark coming from the coil but no spark from ther etheir, the following parts are brand new the distributor cap wires plugs and ignition coil. im gettign power to the ignitor so ther is no short, cna the ignitor be bad???
supra*13
massachussets
i already did, i even put the number 1 cylinder at tdc and put the rotor at number 1 wire,i checked from spark coming from the coil but no spark from ther etheir, the following parts are brand new the distributor cap wires plugs and ignition coil. im gettign power to the ignitor so ther is no short, cna the ignitor be bad???
Mondo
132
Wisconsin
Check to see if its getting fuel.
supra*13
massachussets
OK i will but why would not having fuel cause me to loose spark or is ther anything that can cause me to loose both i already replace the main relay to see if that was the problem but no luck i really need to get this running.
Mondo
132
Wisconsin
Read your reply wrong. Get a multi meter and measure the resistances and current.
Values should be in a haynes manual somewhere. if you dont got one, get one. Its your new bible.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
just curious, does it even turn over? does it try to start, or do you hear a clicking noise and nothing happens? i have a auto converted to manual and i left the auto ecu. i bypassed the neutral start switch with a wire. if this happening like i stated above, then check there. but if it turns over all day long, disregard what i said. ;]
nightrider760
219
escondido , tijuana
not to highjack you thread and bother to double post, but iam having the issue.The other day i was driving it and all of the sudden it died. I also converted from auto to m/t but mine turns over but it still cant get any spark
supra*13
massachussets
same here it turns over fine maybe i installed me distributor wwrong but i dont think i did. this wouldnt cause not getting spark from the coil so idk. im gonna do some testing see wat i find thanks for the tsrm page that helps alot.
supra*13
massachussets
yea i already replace the main fuse but im getting power to the the coil i dont think the ignitor module is bad this is so frustrating :3d_frown:
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
Check for voltage at the high tension wire. If the ignitor and coil appear to be functioning but you have no spark then the wire, cap, and rotor are suspect.
supra*13
massachussets
the ignito seems to be working properly but no spark from the coil but i dont think thats bad because its brand new im gonna try using another one see how that goes
