Need help asap with window
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I need to know if it's possible to raise the window if there isn't any power. The bat is dead and possible wiring mess, but the window is down and it's raining. Lets also assume the motor for the window is toast. Can i manually raise the glass? There must be a procedure...
eric
Bishop92t
773
USA
www.ma70.com
Not easily. You can try applying 12v directly to the motor and it should move. It's not that common for our window motor to fail, I'd suspect relays, fuses, wiring before I suspected motor, so try the 12v to motor first.
Stretch
Toronto, Ontario
thanks for the ideas guys. There is a garbage bag on it right now, and we just got the hardest storm in like all year ahaha so we'll see if the interior is a pool now :biglaugh: Which wire is + and - bishop? One is red and the other is green i think.
eric
