Need Advice on 2 step install
mobes
Supras are never 'done'
Bozeman, MT
Doh! I saw EMS and thought someone had mentioned AEM somewhere in the thread. I guess that makes my last 2 posts pretty pointless then.
As you were :)
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
annoyingrob;1048511 said:
You mean ALWAYs on, under the pre-determined speed. Mine kicks off over 6mph. I've never had it interfere with any of my driving in the last few years.
The ONLY thing I can't do is rev above 5000 while stopped. Funny, It's never been an issue.
Yes thats what i mean. Difference is, i like freedom, if i want to hit rev limiter i will. That and i think 5000 is kinda high, unless you have slicks and a strong ass lsd that is.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I do have slicks. IMO, a 2-step is completely useless on street tires. If you can break loose your tires without a 2-step, adding one is only going to make it worse.
And if you do think it's too high, I do have an interface wired into my ECU where I can adjust it between 3000-5200 at the turn of a knob if I so choose.
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
a strong LSD along with slicks i mean. And if i ran a two step (or when i do) it would be around 4k which i do hit every once in a while. What kind of lsd do you have?
annoyingrob
Boosted member
Jul 5, 2006
2,304
I had always thought it was a standard JZA70 torsen, but I have a suspicion it may have been upgraded at some point, as it's still in one piece. Maybe I should pull it out and inspect.
