I'm currently running Maft-Pro speed density with Greddy 720 injectors. My main scale is at -25. I don't have a problem with WOT tuning but at idle if I tune it to 14.7 A/F the car tends to die if I press the gas lightly. Just cracking the throttle a small amount and releasing the RPM's raise slightly then drops, the car will shudder at the low RPM's before dying. If I tune the A/F ratio at idle to a more lean condition (16-17) the car won't die so easily when I press the throttle barley at idle but the car sounds terrible when the idle is set so lean. I was wondering if any of you other guys have any advice for tuning the Maft-Pro while running large injectors. Thanks.
