Natalya has a 1JZ! (56K Go Home)
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
Well, I decided to have a little fun tonight. I was bored on the freeway and I told myself "It couldn't hurt to give it a bit more boost."
Well, I was cruising in high boost @ 60%. This is about 1.3 Bar for me. I turn it up to 70%. Then 80%, just giving it a quick pull in 4th then letting off. Literally only about 2 or 3 seconds of this each time, and now I'm at about 1.8 Bar. In a moment of what I can only call pure stupidity, I crank the knob to 90%.
Well, I hit 2.0 Bar. I was amazed. As soon as I get there it feels like I hit a brick wall. Okay, I'm done, I hit fuel cut. Noooooooo.........
It wasn't fuel cut. Now my AFC Neo is telling me I'm at -7 kPa while cruising, the wideband reads 10.0, and it won't boost worth a shit. Now I'm thinking "I just blew up the twins." I got lucky. The only thing that happened was the line for the MAP sensor blew off.
Never again...
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
lol...man I remmeber mentioning to you sometime back ....to "Make sure your vacum hoses are zip tied or clamped" lol
Never again...
suprastanger507mgte
Hayward , Ca
BlackMKIII;902196 said:
Right there. Bam. :D
Doesn't help much on the MAP sensor, though. It doesn't have a lip. :(
Use a vacum hose that has thicker sidewalls. ( there are two kinds and I hate the one with thinner walls). I have had good luck with those.
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
So... I went and dyno'd the car today. This is what I learned:
1) Mustang dynos really ARE bullshit. :mad:
2) I am NEVER going back to that shop ever again :rant:
3) My AFRs are on target. :D
I need to set up an appointment with Blacktrax for a REAL dyno, now...
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
BlackMKIII;894928 said:
Ordered a GReddy PRofec B Spec-II from Zankoku last night, it goes in Friday night. Can't wait for 15 PSI (with the silencer in :D). :runaway:
Are you gonna get the steering wheel mounted button that allows you to switch from low and high boost? :)
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
BlackMKIII;904581 said:
276 RWHP / 265 RWTQ
AFRs were dead on 12.5
But I call BS because at 17 PSI I should be pulling more than that. Somewhere in the low 300s.
I think Joe's 1JZ was blessed by a Hindu Guru or Japanese Monk.
I haven't seen his numbers yet on a "stock" 1JZ.
Find a real dyno and use 4th for Dyno pulls. :icon_bigg
This setup should be 300ish. Did you check for boost leaks?
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
from my experience with mustang dynos, they are sometimes 20-30whp low after seeing local supras dyno on a mustang, then go dyno on a dynojet
